Help identify 2 bottom plow
boboiatl
New User
I need to replace my worn parts on my plow but I do not know what brand it is. I did find this picture on the internet but still i cannot tell who made them.I am just trying to find the part # for shims and shares so I can order them. Thanks for any help
a
looks like a Mpls Moline. Check on castings as on rear wheel hub for ID like MM or IHC, etc. Or on parts of it. Many as MM had a stapm on rear of moldboard.
One vote for John Deere. Measure bolt spacing and placement
on plow point for a better guess.
I believe you have an IH 209A, making it a three point hitch plow. you can see its an IH plow because of the trips on top of the bottom support arm. I have one just like it but its the two point version witch is the no. 209.
have you taken a share off? usually there are numbers imprinted into the back side of at least the share. it looks like an IH plow to me too.
More views please. Left side, right side, front, and some closer up would help as well, just do not get too close you cannot see anything.
Ok I have been able to gather the part numbers off of the old parts and have found the correct number for the shins at Wiese industries number( 488266R1). They did not have the Share part number( 463227R1) but I did find it at Duffield equipment so I should be able to order them. It would be nice to order them from the same place though. Any ideas would be appreciated and I would like to thank everyone for your help.
New number for shin is 179318A1 you need parts for 14" Super Chief bottoms and the Share is an early 3 bolt style not sure what replacement number is but one is still available from your CaseIH dealer
IH Super Chief bottoms. Check prices before you order shares. You've got the early (1956-1960) three bolt share. You can make the later and more common 4 bolt share work if it's significantly less money. The right (wing end) bolt holes match up; you'll just have to blow a new hole with the torch for the left most hole. So that would be the 4 bolt Super Chief share from Wiese.
Thanks to the information from everyone I was able to get my plow parts from DUFFIELD EQUIPMENT IN MARYLAND. I called on a tuesday night at 7:30pm to leave a message and someone answered to my surprise. He said he was trying to get out the door but took all my info and said he would call me in the morning which he did. He knew what I needed and shipped it out and I received it Friday and had it all on saturday. What a great experience from this supplier.
