Farmall706guy
I have my TA and clutch all adjusted, i can't remember exactly how to do the trans brake again.... when the clutch is all the way up, the linkage to the transbreak is tight. when i press the clutch half way down, the trans brake linkages are all loose, when i press it the rest of the way down, the linkages tighten up..... basically, when the clutch is half disengaged, ( in the middle), the trans brake linkage is loose, if i press clutch all the way down, the brake goes one way, and when i let the clutch all the way up, the trans brake will go the opposite way... what position should the clutch be in when the trans brake linkage is loose?
