1957Ford600
New User
The key holding the timing gear to the camshaft needs replacing on my Ford 600. This model has the spring clip rather than the bolt holding the timing gear. Is there a way to
change the key without removing the engine and camshaft? The aftermarket manual I have says I need to remove the camshaft. It appears like the end of the camshaft is larger
than the diameter of the actual shaft so a gear puller won't work. Hope I'm wrong. Thanks for your help. Russ
