560 Farmall IPTO seal kit
I have a 560 Farmall and the IPTO seal is leaking, my question is the only bearing and seal kit I can find it says (Farmall TA SMTA 400 450 560 torque amplifier gasket kit). The gaskets look the same, but will the big O ring and the seals work on my 560 that has no torque amplifier? Thanks
Two PTOs were used on the 560 so make sure you are looking at the right parts list. Late tractors had a clutch type, early used the planetary type like the SMTA-400-450 had.
I took the plate off of the middle section, the oil is leaking from the top small shaft at the housing at the back of that middle shaft.
