Gerald12/48
New User
I just joined and an in need of some ideas on my 1972 ford 3000 tractor, engine rebuilt crank turned, new liners etc. all together installed started no oil pressure installed new oil pump still no pressure hooked up a weed sprayer and pushed oil through the sending unit hole in the block ran a lot of oil out of the rear main crank seal, replaced seals, no oil pressure,I do get a stream smaller then before coming down behind the rear main bearing.i don't know if I left a plug out some where or if it is something else have checked the galley plugs in the front and rear of block they are in. Any help is sure appreciated.
