tire/wheel weight
88-1175
20.8x38 on a white 2-135 cast center,need an estimate on the weight.have a case 480d hoe to move them,wondering if I should break them apart,as in tire/rim from the cast center ??
Probably 1000 each for the tire set as described might be a bit lighter. Depends on if it is loaded tire, or just air. Yup poor backhoe that will not lift it unless it is an old hoe from the 50's then it might.
forgot to add their loaded,suppose to be to the top of the valve stem at max height.need to get them off tractor and onto gooseneck
