jim in dover kubota
ben brown
has kubota made any changes on the RTX1100C utv this year like added hp mine is needing new tires so hell mabe i just replace the it with a new one
I bought a new RTV-X1100C about two months ago.
I am aware of no recent changes.
Dean
Ben The answer to your question is really yes and no. There are several running changes to the c in placement of cooling , some of the shift cables and other minor things but nothing that would affect the horse power. Keeping the air cleaner fresh and clean helps they really like fresh air and tweaking the hydro/throttle adjustment is about the only other thing I can suggest.
(quoted from post at 14:40:45 11/04/17) Ben The answer to your question is really yes and no. There are several running changes to the c in placement of cooling , some of the shift cables and other minor things but nothing that would affect the horse power. Keeping the air cleaner fresh and clean helps they really like fresh air and tweaking the hydro/throttle adjustment is about the only other thing I can suggest.
WELL any way when i go into colo.. western slope where i was raised it really like to smoke at 7 to 8 ft it smoke like a fright train it help that i have the optional hand throttle put wide open use the ft control for speed been thinking turbo kit just not sure i want spend the 2 plus grand for a mouth of no smoke in the moutians
I cannot say, we are just over 800ft above seal level here but the folks that have added the turbo kit mostly just got bragging rights. But at your high alt. additional air would stop the smoke. As I commented above seems lack of air really affects that engine. We do see reduced performance with clogged air filters. IF you go the turbo route get someone with a proven setup, we some that looks like they were cobbled up in a garage.
(quoted from post at 17:15:45 11/04/17) I cannot say, we are just over 800ft above seal level here but the folks that have added the turbo kit mostly just got bragging rights. But at your high alt. additional air would stop the smoke. As I commented above seems lack of air really affects that engine. We do see reduced performance with clogged air filters. IF you go the turbo route get someone with a proven setup, we some that looks like they were cobbled up in a garage.
i agree on filter i added a extra radatior hoes so i could rout it back away from pointing to the front where it suck it selffull of trash when i went across a CPR field i looking at one southwest ag in bayler colo.. they clam thy tested there in the mountains but who knows
