Hobo,NC
- Location
- Sanford, NC
I have procrastinated enoufh had to do a few paying jobs today while fiddling with my truck. Pulled it in Monday afternoon draind the oil pumped the radiator up to 16 PSI came in this morning its still at 16 PSI no coolant in oil drain pan. Started my journey going after the glow plugs pulled a valve cover and this is what I found.
Knowing I am gonna get deep into it I pulled all the rockers then went after the glow plugs. #8 tip on a glow plug MIA lower right one.
Used shop air to apply air pressure to each glow plug hole #8 is the leakier no glow plug tip to be found. I removed the injectors and have the rad pumped up no leak so far looks like injector cups are good. Going to pull heads tomorrow are thanks giving day.
