Bruce from Can.
- Location
- Woodville, Ontario, Canada
If you bought standing hay at ten dollars per bale, and you cut rake and bale, assuming a reasonable crop, where do you put your break even sale price/cost. $25.00 ?
(quoted from post at 09:19:34 02/15/18) 2 years ago I cut, raked, and baled 25 acres. got 25 bales, cost $20 bale in fuel. last year same field 50 bales, fuel cost $12 a bale.
(quoted from post at 15:20:47 02/15/18) I need to raise my rates... I do a 10 acre place for $1.50 per bale on the ground.. I dont pick up..usually get about 300-400 bales.. I do this field for a friend that hays but didnt like moving his equipment that far.. Since im in the neighbor hood I do it for him for another guy..
This is my take.. Lets say I get 300 bales at 1.50 per.. that pockets me $450.00 minus fuel, twine, etc..
If I were to do that same 300 bales on a 50/50 share I get 150 bales at my going rate of $5.00 per bale that pockets me $750.00 minus expenses..
(quoted from post at 14:38:37 02/15/18) I leave home with a full tank of fuel, drive to field and cut 25-30 acres (not sure how big it really is, just take his word for it) by the time I'm home tank is empty and I have added 1 5 Gallon jug in the field. JD 4230. same with baling. Then I use almost a tank for loading and running home to unload as I only have 1 tractor with loader. Bales are 1400 lbs.
Fuel is $4 a gallon or more. If I have to rake it cost more fuel. This year I will use a case tractor and see if that is better on fuel.
