What would do? 9N manual starter button
SDE
Part number ABC 066 is for a 9n before serial number 12500. My Serial number 9n9881. It is for a dash with a 7/8" hole. That is what I have. The switch has a 7/8" stem and the push button is 1 inch. That isn't going to work. The body of the switch is too large to mount properly without making contact with the Ammeter. So I made two spacers to hold the starter switch away from the inside of the dash. To use this switch I will need to drill the 7/8" hole to 1 inch. I do not like the hassle of returning parts. Also, they believe that they have given me the proper part and I would need to buy a part that isn't for this tractor, in order to make it work. Would you drill it out or should I try to find a starter button with the 3/4" stem and 7/8"button?
TY
SDE
SDE I may still have an orginal switch for the dash. I will check today if you are interested. Email open, joe
Take the switch you got back to where you bought it for refund. If they give you any hassle explain to them it doesn't fit. Then get online to messicks.com and order the correct switch. It will be in your mailbox the next day.
That is an early 9N with the starter button Henry did not like. If it was me I would find the correct one or mount it in a different place so as to keep the dash original
That Switch fits about a million different things and it should fit yours according to what i read. I would tell the seller it does not fit and why and I want the correct switch, thank you very much.
I had called the seller. I even pointed out to them, that in their catalog, the picture showed a switch that had a shaft that had a reduced diameter at the top, so that the button was the same size as the shaft. They said that they would check their inventory and call me back, which did not happen or my answering machine is on vacation. I will not butcher the dash.
TY
SDE
