donahue trailer
what kind of wood would be used to replace the floor there is no wood on it now just the frame I know a person with a portable saw mill that would probably saw me some new floor boards just not sure what to use for wood thanks for any advise Howard
Another vote for white oak, if available, if it's for a heavy duty trailer. If a smaller 16' or so, then nothing wrong with pine.
White oak is a closed-grain wood, which is why it was used for ship building 200 years ago and more. Red oak is open-grain. If you cut a piece of red oak 1" x 1" x 4", with enough pucker, you can stick one end in water and suck water through the wood.
Main thing that trailer wood needs is protection from the elements; mostly water. Not a lot you can do about sun, but water will rot the wood anywhere it can stand or soak in. Some folks like to use pressure treated wood, but the pressure treating is for insect resistance; not for waterproofing. This treatment, however, also helps to ward off the molds and fungi that can cause the wood to rot.
Personally, I like using old oil; motor, hydraulic, or ATF to name a few. Must be applied to DRY wood and allowed to soak in. Sitting in the hot sun helps the oil to penetrate deeper.
Yup, for white oak. Very heavy till it drys out. Then when it is close to bone dry spray it with cheap clean new motor oil. The new oil makes a very pretty job. Drain oil works but looks like all heck. Out in the hot sun and spray top AND bottm. Usually a once a year production. Really makes them last.
In Ohio you do not treat wood for insects, only for water proofing and that is what the pressure treated yellow pine is sold for.
You got that. As a kid the local GLF got hold of a load of those fence
posts. Only way to nail insulators into them was to predrill all of
the holes. Was like trying to drive a nail into an iron pipe. Every
nail bent over.
Semi-flatbed trailers use Apitong wood. They sit out 24-7-365 for years. On a cost vs years of service probably the longest lasting least cost wood.
I have white oak and yellow pine on the place and have sawed boards from them. White oak is ahead by a large margin for trailer floors. Treated lumber here in SC is yellow pine.
No red elm or larch to be found here.
KEH
