rossow (mn)
I am rebuilding a small (4x7) trailer. It has an old beam-type axle from a GM truck, probably a 3/4-ton. The rims are tube-type 8-hole 15x5.5. The tires are old tubeless radials but have tubes and are rotted. The trailer will rarely see off-property use but I want to retain the on-road, short-trip option. I want to use modern 15" radials -- with tubes to accommodate the old rims, of course. (Caveat and apology: I'm only familiar with one-piece automotive-type rims.)
I have a couple of questions:
(1) The rim has an outer ring that is free to rotate on the rim when tire is off; the tire bead seats against that ring. Does that ring affect method for mounting/dismounting? I ask because I usually dismount toward the shallower offset but had a rough time getting the old tire off.
(2) Does anyone know of a more modern rim that will fit the old truck hubs? Tubeless rims would be great.
I appreciate your advice.
