hard start runs fine
Ron Tron
All of a sudden my 9N is giving me a hard time starting but after it runs for a minute or two it runs fine.........What on earth could that be........?
Do some simple trouble shooting.
#1 make sure you have a good blue white spark at all the plug wires that jump a 1/4 inch gap or more.
#2 pull the carb drain plug and make sure you have a steady flow of gas that will fill a pint jar in less then 3 minutes. Catch the gas to look for water/dirt etc.
#3 when was the last time you serviced the air cleaner and dumped the water and mud and filled with fresh oil.
#4 pull the air intake hose off the carb and hold your hand over the intake and make sure you have a good suction there and also you should get gas on your hand.
#5 pull the spark plugs and make sure there on fouled out by sooty or oil.
My self I have switched to NKG3112 spark plugs since the last auto lite and champs I got fouled fast
(quoted from post at 18:44:00 10/23/18) All of a sudden my 9N is giving me a hard time starting but after it runs for a minute or two it runs fine.........What on earth could that be........?
Does the choke plate close completely?
(quoted from post at 10:59:31 10/23/18) Do some simple trouble shooting.
Thank you for that.........I needed a game plan....I'm also going to check the in line fuel filter
