Shenniu 254 Hardy diesel
Pete_5959
Good Morning All,
Came across this tractor with 45 actual hours on it. Original owner says it wasn't running well and he parked it 12 years ago. Replaced filters and fresh fuel. Starts but has no power. Exhaust pipe gets cherry red pretty quick. Any guidance/suggestions truly appreciated.
r/
Pete
Since diesels have no electrical system to go haywire, pretty much has to be injector pump, or the supply of fuel to it. Check fuel supply first, then maybe you can get one of the injector pump guys on here to help. Not sure if any of them has the motto "If we can pronounce it, we can fix it."
Google Shenniu 254- it gets you about 80,000 hits.
If it were a gas engine, I would suspect retarded ignition timing.
Not sure if diesel would react the same way, but maybe the pump timing is off?
With exhaust getting red hot and no power that is symptoms of blockage in the exhaust.
