Guys,
I am replacing all the gages on my 1965 Massey 165, gas burner. My temp probe will not even start to come out, and it is the brass type fitting with the probe capillary coming out the center. Can't get a wrench on it, and if I use a socket I will need to cut the capillary tube. I have had it soaking with Kroil for weeks and tapping it with a flat punch on one of the hex crowns to try to start it to rotate. Also tried an air powered chisel with a flat tip, not on full speed. But it is deforming, and I am afraid it will break off leaving the body in the cast iron part. Trying to do this without removing the cast iron coolant block from the engine. Figure that would be a disaster, too. How to remove corroded water temperature probe from engine? Any good tips?
Can it be drilled out without damaging anything?
Any ideas would be great!
Thanks!
Brent
Thanks!
Brent
