Geo-TH,In
My new 20v dewalt batteries won't charge if they are cold or too hot.
GM recommends using a charger designed for AGM batteries that keeps the charging voltage under 14.8 v.
My car has set inside a 50 degree garage for past two weeks. Lot of bells and whistles that drains the battery. BTW< GM recommends not using a trickle charger.
Went out of town the other day. Turned the voltmeter on display. Charging voltage went to 14.8 v for about 30 minutes. Then slowly it increase to 15 v as the battery cooled off, 15 degrees outside
We stopped for lunch for about an hour.
On the return trip, 150 miles, the charging rate went to 15.2 volts. So much for keeping charging voltage below 14.8 v on an AGM.
I'm only guessing that the car's computer looks at temperature and adjusts charging voltage.
I connected my battery minder to a cold battery in pole barn. It too has a temperature monitor. Charger didn't want to work in the cold.
Does anyone have a link to show that temperature has an effect on a battery's ability to be charged? I read someplace that booster chargers capable of 200+ amps may cause a COLD battery to fill with hydrogen and go BOOM.
Anyone experience a big bang using a booster chargers on cold batteries? I saw one. Big flash and acid all over. Lucky no one was close to battery at the time.
