Wheat 47 Pasquali
DIM
Wheat47 What about the Pasquali tractor. Did you get it. Was it any good. What was it worth.
I looked at it last night. It's a 977 model.
Pretty sure I'm gonna take it. Still negotiating a bit.
Trying to get him to throw in a couple of snow blades off a pickup. Would mount one on the tractor.
He's asking $3500 (plenty). It's partially disassembled. Hood and grill off, fuel tank
and bracket off so he could put on a new starter. There is a loader to go with it, but it needs a
new control valve (gone) and new hoses. Gonna start checking on that kind of stuff. Probably
$5-600(at least) right there. It has the wide fat tires on it (31x15.5-15) so it's 60 inches wide,
plus the tires are full of CaCl2. The tires are decent, tho.
Can't get it 'til snow melts, tho. (Unless I get it running, probably a day's project, alone.)
But I think it will be an OK project.
My friends Pasquali's cost him 500 but was in bad shape. motor stuck, fender missing, seat missing, steering wheel bad,two bad gears in transmission and needed wheel seals. by the time he gets it done he'll have 3000 +.I have a CAST tractor. It's a vineyard tractor also but a little bigger. The CAST has more things like 4 wheel brakes,( still not every good), seat rotates around steering wheel and you can drive it both ways. You can lock both front and back rear ends. The same hp as the Pasquali. The CAST is four wheel steering not articulating. The CAST is the most fun I've had driving a small tractor. If you get the Pasquali I think you will enjoy it. My CAST doesn't have a loader but I found a second one that does. I need to get the second one in the shop and work on it. Be glad help with the Pasquali I don't know every thing but I can help with what I learned.
kcm...it tried to send them, but said mailbox was full. I just cleaned it out, maybe try again.
Thank you.
Sorry, I'll have to charge you for a 2nd try.
What'll it cost?? ....You can email me a pic or two of any tractor you'd like used in the daily pics. Can be any tractor you choose; yours or from online. :wink:
You know, strangely enough, I don't have any digital pic's of
my stuff. Give me couple days and I'll get some "snowy" pic's of them.
