Will Herring
So I have an 8' or so hydraulic disk (John Deere KBA maybe?), and I put it on the tractor tonight to go out and play around where I did some plowing last fall.
The earth was cutting good, but dang if this thing doesn't leave some high and low ridges and just... Not want to track that straight.
Do I just have a worn out disk, or is this a common problem? Also, should I be taking half cuts, full cuts, double cuts... Cross cuts... What's the trick to getting the most out of discing.
