o, they both see several hundred volts in normal operation.(quoted from post at 12:00:09 05/20/19) Is there a difference between a 6 volt system condensor vs a 12 volt?
If the condenser is undersized or not even there at all, the coil can still produce a spark, but the points will burn prematurely. " Yes,'a spark'.....but in many cases it will be of insufficient energy to make an engine run, as so much of the energy stored in the coil will be dissipated in the arc across the opening points, that would have been quenched by the condenser and thus applied to the spark plug arc.(quoted from post at 13:36:56 05/20/19) Hadley, great question here's the deal.
First of all, regardless if the condenser (aka Capacitor) is used in a 6 or 12 volt system, that's (6 or 12 volt system relative to the condensors insulation properties) in the scheme of things NOT MUCH DIFFERENCE. The voltage withstand rating, or the insulation value if you will of the condensor, IS MUCH HIGHER THEN 6 OR EVEN 12 VOLTS anyway and may be the same if used on a 6 OR 12 volt system. The critical factor is the capacitance which, if properly matched to the inductance of the coil, increases the life of the points and reduces the situation where there's mounding on one set of the points and deep pitting on the opposite side, one among other SIGNS OF AN IMPROPER SIZED CONDENSOR.
Some time back I spoke with a rebuilder who claimed nearly 50% of the condensors he buys in bulk are out of spec grrrrrrrrrrrrrr
SUMMARY there's not much if any difference in the voltage withstand or insulation value of a condenser regardless if used on a 6 or 12 volt tractor HOWEVER there's a HUGE difference if its not sized correctly to match the coils inductance.
Hope this helps, best wishes n God Bless
John T
O! You can't make energy, just convert it.(quoted from post at 18:48:33 05/20/19) Here we are looking at a small ing. coil. What if we wound up a coil with miles of wire? Put a small charge to it & what would be the outcome? Way more than the input!
orry, bubba, the energy is all gone before the points close again. Study the scope trace presented. Then go do other studying, we can't educate you in a YT post. Study! Study! Learn! Or would you rather just jaw?(quoted from post at 21:32:32 05/20/19) The voltage spikes seen at the condenser are being produced by the windings of the coil triggered by the 6 volt input. The energy stored in the condenser is lost when the points close & it goes to the ground.
think you should just connect your toaster to your tractor condenser & enjoy! :lol: :roll: :twisted:(quoted from post at 08:34:03 05/21/19) If your mind is closed, you have to open it as I can't do it for you. His machine, Big Eureka was putting out around 7000 times the input. He hooked up a generator & made it self=running & was dead shortly after. Wonder why?????
