Valiant Farmer
I've been diving into my Dexta, starting to seal up major engine oil leaks, finding several missing bolts.
Now it is turning into a nightmare...
As the gasket behind the rear crank seals, and now as the sump gasket, I have found that the last mechanic used (as gasket paper) some sort of extra tough gauze, with triple strength superglue, that sticks the surfaces together so tight I could barely pry them apart, and a wire wheel on a drill refuses to move it, unless I scuff the surface with a rough sandpaper.
What is this material? How to remove it?
Any help appreciated!
Joshua
Joshua
