Dave Westlund
Hi All,
I could use some advice on a carb I've got torn apart. The carb is a Marvel Schebler TSX755 that has a buggered up nozzle and I can not get the dang thing out. The nozzle is the type that did not have a Nut machined in the nozzle, It did have a slot for a screw driver and the slot was buggered up to the point that a screw driver will cam out of the slot. I've tried heat and brazed a nut on the tube in hope that the nozzle would loosen but no luck. Finally the tube busted below where the tube exists the casting.
Any thoughts on how I should attack getting the nozzle loosened up so I can turn it out would be much appreciated?
Dave
Dave
