grandpa Love
Painted the rim from the 640 Ford and 1 rim off the baler. Plan to mount tires this afternoon and don't want to scuff the paint, any tips / tricks?
What would that do?(quoted from post at 16:03:36 09/29/19) Throw the rims in the oven and bake at around 175-200 for an hour. Then turn the oven off and let coll slowly.
Ok. Thank you. I was trying to figure out what that had to do with mounting tires. I'm aware that it's easier to get beads to seal when you warm up the rim, but couldn't see the advantage to letting it cool off again.(quoted from post at 17:55:17 09/29/19) That bakes on the paint so it will cure/harden up fast and then in turn be harder to scuff etc. Haven't you ever heard of the term baked on paint. Was common at one time and there where paint booths with heat lamps in them where something that was painted was then slowly run threw the booth to heat up and cure the paint
