Hello everyone. Im in a bit of a situation here and need some input as i'm sure some of you have been in this situation before. I have an 01 ram 2500 with the 360 in it. It has 132k on it and 1 spec of rust from a paint chip I foolishly ignored. The engine has developed some mechanical issues as well as the front driveline. In short it would need 3500 dollars worth of work to bring back up to spec. The big items are intake gasket, cylinder heads, and a new front driveshaft. I am a cat technician and will be doing all the work myself. Is it worth fixing this truck or letting it go? I pull my pulling tractor with it and potentially my mother's camper this summer. I have already put a better built transmission in it to the tune of 3500 dollars and other things like wheel bearings and water pumps. The value of this truck in kbb is 8800 dollars.
If I do end up fixing it I have a mind to find a good used engine and build a 408 stroker for the truck for some additional pulling power. This will bump the price up another 200 roughly.
Thanks for everyone's insight. Being my second truck I have never run into this situation before.
