ram74
New User
Hi all, wrapping up construction on the pole barn. I put one overhead door on each opposite end so I could drive the hay wagon straight through for loading/unloading. I didn't account for sight slope and the exit door is about 2 feet above grade. The builder piled some excess stone there and was driving his kubota in and out but it is too steep for permanent use. I guess the length of the rock pile is about 4 feet max. the sight continues to slope gradually out from where the ramp would be. I figure i could either move that stone or add to it and build it out.
What should I do with this ramp? Is it ok to just keep piling stone there and maybe top it with flume or #53 to lock it together? what is a realistic slope and length of the 'ramp'? I want to be able to drive either the 8n or the ram2500 through there pulling the hay wagon. The truck has a large clearance due to the factory lift, maybe 15 inches or so.
thanks up front!
Rob
1:12 ramp angle is kinda normal, so with 2' to compensate for, 24 feet should do. Make it 30 and be happy. Were it mine, and had large irregular stone around I would bank each side to prevent the edges from breaking down. Plenty of waste stone around St. Cloud, we mine and process granite here. Jim
I would run it out a good distance with junk fill and then top it with some 1.5 inch crushed gravel to make a good hard surface. gravel terminology is regional so only people in your region will know what 53 or flume are.
sounds good. Where i am located 53 is rock about an inch with lime dust mixed in so it compacts real tight. Flume is basically the lime dust that packs hard.
