Ihave a MF 203 with what I thought was a starter problem. I hooked cables to the starter. It didn't turn the tractor motor over. I removed the starter. It bench tested good, and ran good with jumper cables I reinstalled the starter, still did not turn over the 3 cyl Perkins. The jumper cables got real hot, like a direct short.I thought the motor was froze. Removed the starter again. Turned the motor over with the flywheel. I know the motor isn't stuck. I got rained out before I could do anything else. The only thing I noticed was the ring gear was a little chewed up where the starter engages. Starter small gear extends like it should, when the starter motor spun. I always thought a starter either works or it doesn't. Any thoughts? Stan
