Can you still buy these tires
SVcummins
Miller Tire, Wauseon, Ohio. I bought new front tires and wheels for my '50 John Deere B from them...
Be sitting down when you see the price. I wanted a set of those for my Oliver 880 to replace the originals. I bought two 3 rib and tubes for less then one of those tires.
Hope you have better luck ordering tires than me. The tires I use on my tractor nobody makes anymore. I found some online and ordered them and while they had never been used in less than two years the sidewalls started cracking so I know they had to have been stored a very long time. Then I just ordered tires for my jeep and ordered the same size tire I was using and the tires I got were nearly half the width as what I was expecting. The company took them back but was quite an ordeal.
They would look like a 7.5 x 15 maybe? I do not not think they are tall enough to be a 9.5 x 15. I have 11Lx15 implement tires on the front of my one 4020. It is used on the discbine a good bit and they tear up less ground when turning at high speeds. Tom
I have a pair on the front of my 1520JD, They are hard as a rock and work real good in thorns. Size 6.00x16
SV, way back in the 1950s our JD 420 had those type of front tires, they were good except in wet ground or mud the area between the treads would fill with mud and you would loose steering.
