Lilliston 7-Six
StNick
I have an old Lilliston tow-behind mower, 7-Six. The company was taken over by BushHog but the only parts they have are blades. I am looking for bearings, P/N 01-50-004. I have the manual for this mower. Any help is much appreciated.
You're probably going to have better luck getting a number off the actual bearing.
Failing that, measurements of the inside diameter, outside diameter and width will give any competent bearing supply enough to find a replacement.
There are some other considerations like tapered with a separate race or straight bearing, ball bearing or roller bearing, sealed or open.
Take the old bearings to a place like Motion Industries, or Kaman Bearing. With the numbers on the bearing races, they will match them. Ball and roller bearings are very standardized. Jim
I have several of those mowers , use one and bought more for parts.
the one I use is a 3pt ,but looks like the same deck with other
ways of attaching .3 pt has single tail wheel , trail model has 2
larger wheels on a bar. Those mowers will do as good a job as a
riding mower.
I rebuilt the spindles on mine
2 - 14136A cup
2-14276 cone
2 - 204002 seals
these have no bearing adj , has a large washer welded on upper
end of shaft , set the preload in a press and reweld the washer.
There is a lighter weight trail mower and I have know idea what is it
for bearings.
george
