2510 will not run
730virgil
my 2510 john deere will not run when you take finger off of starter bottom. any ideas? this tractor has electronic ignition.
Turn the ignition switch on, check for voltage at the coil + terminal.
Probably be 0 volts.
Start checking back toward the switch, likely will be the switch.
They have you covered below. Your tractor has ignition resister by pass through the starter solenoid so it runs on the by pass circuit but not through the resistor circuit.
