doublebass73
Anyone here ever run a 3 point hitch snowblower on a narrow front tractor? I was just curious is there was any difference between that and a wide front for running a snowblower.
(quoted from post at 08:28:52 08/20/20) I have. It's nice to be able to turn
while snowblowing and not get one of the
front wheels wedged in a snow bank.
(quoted from post at 09:49:31 08/20/20) Two wheel drive tractors are helpless in the snow
regardless of the front end combination.
(quoted from post at 09:46:58 08/20/20) In my experience dual front tires don't go thru snow very well. The snow
clogs up the tires so the won't roll then they try to skid along and
push a pile of snow ahead of them.
You may be able to widen the tires if they are adjustable but that makes
it hard to turn the steering wheel.
Just my experience.
Dave
(quoted from post at 12:51:45 08/20/20) World of difference using a snow plow or blade than using a snow blower. With a blade on the front or back you can get up some speed, and momentum will carry you through. A snow blower requires the tractor to creep along at the speed the engine can power the blower while it picks up the snow. Go to fast you will either plug the blower, shear the pin or snuff the tractor engine.
(quoted from post at 15:36:56 08/20/20) We run a 7 foot new idea blower on an Oliver 1800 narrow front. No chains, no fluid, no weights just some plane Jane Firestone SAT s and never have any issues. Used to run it on a 77 wide front before that with no issues either and just switched for a little more power and comfort. And for part of our driveway and a couple of the neighbors that we keep clean we are pushing up some pretty decent hills. If you need front wheel assist to run a blower you re doing it wrong.
