New starter
SVcummins
Came today got it put on tonight 4020 starts better than it has since i switched it to 12 volts
Starter drive is broken on the old new starter
Had to put my harbor freight reamer to work reaming out the holes in the cable ends to fit over the stud on the new starter
made my life easier a long time ago and replaced the hind bolt with a stud sure makes it easier to work on
Good luck with the new one.The stud on the back is a great idea!The same thing happened to the FORD 2000,the drive chewed up. Sent for a starter drive,,,it lasted one week,,on the second one now.
Good idea on the stud. That rear bolt was a pain in the rectum. Another trick that may help you out in the future is to use a good appropriate size magnetic pick up tool to start the nut. It works well for small screws and bolts to.
I've put several of those style starters on my Oliver tractors,surprising how a starter with the motor that small will crank the tractor better than the large
original style starters.Plus they are only about $100.
Month ago I replaced the very similar cast iron starter on our dump truck with one of those lightweight gear reduction jobs, it's a IH with DT466. Try that back bolt from underneath or over the steer tire! LOL
(quoted from post at 04:02:59 11/10/20) Good idea on the stud. That rear bolt was a pain in the rectum. Another trick that may help you out in the future is to use a good appropriate size magnetic pick up tool to start the nut. It works well for small screws and bolts to.
"Good idea on the stud."
AFAIK, the stud should have been there from the factory. Most I've ever dealt with have a stud in that location, and that is what the parts catalog lists.
(quoted from post at 06:22:56 11/10/20) I found a chevy distributor wrench worked.
A 1/4" drive 9/16" socket with enough extensions to get past the front of the starter solenoid works GREAT.
(quoted from post at 06:29:03 11/10/20)
My 2140 has that stud in place for the hard to reach side of the starter and I believe it is original equipment. I think I am going to have to follow the same idea as my strter is still not working as it should. Needed the battery booster and a shot of ether even a few days ago when the temp was around the freezing point. I know the old 730 Case and Super 90 Massey would have started without that much trouble.
My 3020 came with one and i have abused the crap out of it. They turn the engine so much easier than the big starters do
Who ever designed these starters with a bolt that is impossible to get to needs shot this one isn’t that bad
(quoted from post at 08:57:07 11/10/20) Who ever designed these starters with a bolt that is impossible to get to needs shot this one isn t that bad
I installed a starter on a 6400 with loader mounts yesterday.
Makes a 4020 starter job look like child's play!
(quoted from post at 08:48:24 11/10/20) Parts catalog lists three 1 1/8 cap screws
INTERESTING! Must be an older/different PC! This is for the early 4020's, the PC for the later 4020'w shows the same thing.
Look at Key #'s 6 and 9, footnote "A" = diesel, "B" and "C" = gasoline and LP.
Might as well get the drive for the old one when that new one shells out. Guys have bragged about them, but didn't get much life from them. Don't think about putting one on your 3020, you will be digging the nose cone out from the flywheel housing. chris
(quoted from post at 23:35:27 11/09/20) Came today got it put on tonight 4020 starts better than it has since i switched it to 12 volts
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto62491.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto62492.png">
It looks like you traded up from an old Delco to a new permanent magnet Denso starter. No wonder it starts so good.
The 3020 came with one on its third year ive got it so hot that i melted the stud into the starter its held up a lot better than this pos i just re replaced on the 4020 which is on its second solenoid and now a starter drive and it was 450$ still no broken nose cone on the gear reduction starter or any major problem
I just shake my head at some of the low prices quoted on new starters here on the forum. I looked up one for my 2140 on Amazon. AR70436. Its cheap enough at $140 but then there is $122 shipping charges. I'll keep looking locally.
(quoted from post at 20:18:59 11/10/20) I just shake my head at some of the low prices quoted on new starters here on the forum. I looked up one for my 2140 on Amazon. AR70436. Its cheap enough at $140 but then there is $122 shipping charges. I'll keep looking locally.
Here is what that 2140 needs to wail it over on a cold day . A 4Kw gear reduction starter. Why settle for a scrawny 3Kw starter ?
I forget ,Did you get around to installing a destroker on that front pump ?
(quoted from post at 17:33:00 11/10/20) That does not look like my 2140 starter. Numbers don't match up to any of my searches. I found one listed at A&I matching the original JD number. Original style Bosch starter at $349 before shipping. Have not checked with JD yet.
I'll concentrate on the starter before doing anything about a destroker. I know the starter is bad.
just put a cough drop paper over the nut then put the nut in the shallow socket... then the nut will stay in the socket..
Poor rednecks have poor ways...
(quoted from post at 21:46:30 11/10/20)
Why are you stuck on a factory appearing 3Kw starter instead of 4Kw starter that will improve cold starts ?
If I have to order in something from far away, maybe from the U.S. I want to be hundred percent sure it will fit. Don't want to have to return something that heavy considering the shipping costs. That one you posted does not look like it will fit my 2140. I've got two mounting bolts and ten tooth gear.
