54Chevy
New User
I recently got a Ford lt110 and it needs some work I was wondering what kind of battery and belt does it need and where I could find a seat at
(quoted from post at 17:51:44 11/27/20) What kind of battery would I need?
12volts DC
I would measure the battery box or compartment.
Note what type of battery cable ends on tractor, such as bolt on ring type or clamp on type like a car.
Note how long and where the battery connect cables are to determine if it will matter to get a left hand or right hand battery.
Also make note of the battery space height so that when everything is connected, ready to run, terminals of battery does not touch anything.
And you do not want a battery that is too tall for the holdown to work.
My email is open. I have 11 Jake built lawn tractors. I'll take some pictures of seats and send
pictures to you.
The battery is a standard garden tractor battery. It is 12 volt, negative ground. If you are sitting ou
your tractor, the posts will be closest to the dash. The left post is negative and has a very short
cable bolted to the battery and to the dash. The positive cable goes behind the dash and connects to the
system.
