Tractorcedric
- Location
- Garland. Utah
My plan is to mount this John Deere 60 inch mowing deck under a CA Allis. To drive the mower I needed to mount a second pulley to the center pulley. I needed a way to center the aftermarket one I got at Tractor supply. The hole in it was about 1/8 inch smaller that the hub of the center pulley. I had some tool cutters so I made a tool holder out of a scrap angle iron and drilled some holes to hold it in position. Then I turned the blade from underneath with my left hand and slowly tightened the nut as it cut the edge of the hub. Now the new pulley will "center" and I will just tack weld it to the lower one. Hope the pictures work.
