John Deere 350 Dozer Bucket Loader with Backhoe
Dcostamello
New User
I have a backhoe that does not allow hydraulic pressure to come to the two main lines that you connect to the quick connect back hoe. I have no hydraulic pressure on the main lines going to backhoe. Front end loader has plenty of hydraulic pressure. It works perfectly. The rest of the machine operates perfectly except the two back lines you plug into the backhoe. Maybe you could tell me where I should start looking for a problem. Thanks.
Does it have a diverter valve that has to
be turned to supply oil to the hoe? Or
something in a quick connector not
allowing oil flow?
Some had a Tee handled valve behind the seat back you pulled up on. And like the other poster said, could be you quick connects are trashed or it could be the interior of the hoses are collapsed. I'd pull the disconnects and turn it over, see if oil flows to start. It could also be the valve body on the hoe. Start on the tractor and work through the system.
