Northern tool
SVcummins
Refunded my 39.00$ and are sending me a 50$ gift card for the great engine stand scandal so I guess I still like them
So what happens to the parts that are lost ? Somewhere a FedEx warehouse has to be wondering what these things are
Probably or a flower pot . I made do with standard bolts or it would of cost me as much as a new engine stand
I like what you did with the outriggers. It will be a lot more stable now. Scrape the paint out of the inside of the tube and coat it and the support bar with cornhead grease. It will then spin so easy even with an engine attached you'll wonder why you even thought about needing a bearing.
I was wondering what grease I should use I might even have a tube of corn head grease In stock . The legs make it 2 feet wider so it shouldnt a lot more stable now
The plan is to put two bearings back to back on a base one bearing will just twist out of the pillow block then turn the shaft down and use a double sprocket and chain coupler to attach the gearbox to the shaft
