8000 Ford tractor steering problems
Rgibson
New User
8000 ford tractor When turning to the right all the way it does fine when you turn back to the left all the way when it bottoms are hits the stop the pressure line blows off the steering motor and tilt mechanism
(quoted from post at 09:10:36 03/26/21) 8000 ford tractor When turning to the right all the way it does fine when you turn back to the left all the way when it bottoms are hits the stop the pressure line blows off the steering motor and tilt mechanism
"the pressure line blows off the steering motor"
Can you give us some more details, does a hose blow and need to be replaced each time, or does a threaded hydraulic fitting or flare fitting or swivel pop out of place?
AFAIK, the steering pressure relief valve is in the pump and it is strange that it wouldn't protect the system from over pressure in both steering directions.
Pressure line blows off at steering motor on compression fitting replace compression fitting still does same thing going to go get a different type pressure 90 fitting to see if that will hold
(quoted from post at 06:20:20 03/27/21) Pressure line blows off at steering motor on compression fitting replace compression fitting still does same thing going to go get a different type pressure 90 fitting to see if that will hold
Are you using the special steel "swagelok" type sleeves required for hydraulic use or ordinary brass "ferrules"?
