(quoted from post at 07:35:10 04/16/21) I'm sure all of you have grease fitting that you can't squeeze grease into. What options do you have-i've put new grease fittings & you still can't get grease in them. I have just a standard grease gun & another grease gun with the clamp on it.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto85234.jpg>
(quoted from post at 08:45:28 04/16/21) The most likely problem is hardened grease in the joint.
I've had intermittent luck with one of those impact tools for freeing up plugged zerks. I see Lincoln makes a kit that uses a screw-in ram that allows you to control the pressure better. Lincoln 5805 if you're interested.
Other than that, take the zerk out, remove what you can with a pick and squirt your favorite penetrant into the hole in hopes that it'll soften the grease.
(quoted from post at 09:00:52 04/16/21)(quoted from post at 07:35:10 04/16/21)
Hey Jim, I just replied to your post from back in December about your Work Bull backhoe problem.
The reason I mention it here is because if you use classic view I doubt you will ever see it otherwise.
(quoted from post at 17:58:21 04/17/21)(quoted from post at 09:00:52 04/16/21)(quoted from post at 07:35:10 04/16/21)
Wait, sorry, I got the wrong guy. Carry on.
