Marvinrussom
New User
I finally got my AC WD 45 going. I hooked her up to my disk
and made a few rounds but when I pick up tne disk at the end
it leeks back down before I can get turned around what gives?
You have a bad oil leak somewhere. Do you have another implement with a cylinder on it? If so hook it up and see if it will hold a load up so that you can tell whether the problem is in the tractor or the cylinder.
If by pick up disc you mean it is a mounted disc, You most likely have one of the following problems. One of your lift cylinders is leaking. One of the hydraulic lines to the lift cylinders is blown. The hydraulic pump linkage is out of adjustment. The hold position check valve in the pump is not seating properly.
O boy alot to check Fluid is full and looks pretty clean so I think thats OK there is a split spot in one of the hydraulic hoses but its not oily like its been leaking and like I said the fluid is full so it would seem that it might be an internal leak like that hold position valve you were talking about
