slime is not in a aerosol can its in plastic bottles or jugs you squeeze or pump in in through the valve stem you can get it bout everywhere walmart tsc rural king ect(quoted from post at 00:17:39 01/27/22) Good evening, Mike M and all: I think I understand that slime (or similar product) comes in a sort of rattle can, with a nozzle that screws into or onto the tire's valve stem. How does the slime affect the valve core? Can you still add or remove a little air as needed over the years?
BTW, I have a product called Fix-a-Flat in a pressurized can, is this equivalent to Slime? I don't know where/when/how I got it....
Thanks for any info!
Dennis M. in W. Tenn.
(quoted from post at 14:01:55 01/26/22) I usually remove my tire and repair the tube. My trailer is a tubeless tire. The rim is beat up and the tire has a very slow leak at the bead. I am going to try the slime sealant. Anyone had luck with this stuff? Stan
(quoted from post at 18:24:00 01/26/22) and when your poor you do things just to get by. many times its not correct. and yes this crowd always has overreactors and stuff keeps getting passed down the line. i always wonder if even half of some posters have even experienced what they post. then there is the ones that look up stuff before posting it,... well just because its online dont make it correct. lots and lots of that garbage on u tube.
(quoted from post at 16:01:55 01/26/22) I usually remove my tire and repair the tube. My trailer is a tubeless tire. The rim is beat up and the tire has a very slow leak at the bead. I am going to try the slime sealant. Anyone had luck with this stuff? Stan
(quoted from post at 00:08:27 01/27/22) Well that didn't work as planned. I let the remaining air out of the tire to screw on the pressurized can. The tire came loose from the rim on both sides. The only way to reset the tire on the rim was to use starting fluid and blow it back on the rim bead. I didn't want to do that with that stuff in my tire. I put the slime in the front tire of my JD with a slow leak. I ordered a new tube for my trailer tire. I just wouldn't have a spare tire tomorrow for my mowing job. Stan
(quoted from post at 07:36:21 01/27/22) Well you can put diesel engine oil on the list and no I'm not a troll, I experience it every time I go to the auto section at wallyworld these days. On the word troll, I used that word when fishing: Put a bait on your line, have your boat running at some slow speed, drop the bait over the side and hope some fish it dumb enough to bite it!
(quoted from post at 12:43:05 01/27/22)(quoted from post at 07:36:21 01/27/22) Well you can put diesel engine oil on the list and no I'm not a troll, I experience it every time I go to the auto section at wallyworld these days. On the word troll, I used that word when fishing: Put a bait on your line, have your boat running at some slow speed, drop the bait over the side and hope some fish it dumb enough to bite it!
[b:cec035babc]Means pretty much the same thing on the Internet.[/b:cec035babc]
