john in la
Can you charge 2 deep cycle 12 volt batteries hooked in series with a single 12 volt charger without disconnecting the batteries???
How would you hook up the charger????
hat's kinda the same thing as when you hook a charger up to a dual battery pickup truck. The batteries are already wired together in series and you just hook the charger to one of them.(quoted from post at 00:52:47 06/01/22) Can you charge 2 deep cycle 12 volt batteries hooked in series with a single 12 volt charger without disconnecting the batteries???
orry. I misunderstood.(quoted from post at 01:13:19 06/01/22) reconnect them parallel
Not an option.
I need 24 volts.
(quoted from post at 21:25:56 05/31/22) There would be zero load while charging.
This is for a boat trolling motor.
I can get a double bank charger for about $150 but I already have a single bank charger.
I'm changing from a 12 volt motor to a 24 volt motor.
(quoted from post at 19:57:03 06/01/22) Pretty close.
I have a 12 volt salt water trolling motor; a single 12 volt battery; and a single bank 5 amp NOCO mounted charger.
My trolling motor let out the smoke and needs to be rebuilt or replaced.
A friend just upgraded his 24 volt hand steer trolling motor to a GPS guided I pilot.
He said I could have his old motor as long as I used it.
If I decided I did not like it to bring it back.
In other words I can not sell it.
Since I only have one deep cycle battery; and I have been told to replace series mounted batteries in pairs; I now need to spring for two batteries.
In an effort to cut cost I am hoping I can use my existing charger for a while.
I am willing to put alligator clips on the charger wires so I can move it from battery to battery.
I am not willing to wear out the battery connections by taking them loose for every charge.
I will eventually spring for a dual bank charger but for the time being I was looking for ideas that will charge the batteries.
Not sure if I understand Determined post.
I did not think a 24 volt charger would charge two 12 volt batteries evenly.
