From CDL life. A story about an overloaded truck and no oversize permits. Look at the citation at the bottom for overload weight. Oooopps. Needed a stealth truck.
Overloaded truck. 4340 dollars owed
(quoted from post at 17:20:51 12/11/22) I have to question how they weighted him and the accuracy of it. If they didn't put something the same thickness as the scale pads under the rest of the wheels it is not even close to correct. IF you drive on a 1/2 inch thick scale with just 3 axles and the rest are not up there with them they will pull down unevenly causing the figures to be skewed. Thus not accurate. Besides here with a few more axles he would be legal on the weight. His permit would have been able to go to 40,000 per tandem on the truck and trailer if had had them. That would have saved him a bit. Fines must have gone up a lot since I was last on the road. MI can charge in some counties as much as a 1.00 per pound.
(quoted from post at 20:20:51 12/11/22) I have to question how they weighted him and the accuracy of it. If they didn't put something the same thickness as the scale pads under the rest of the wheels it is not even close to correct. IF you drive on a 1/2 inch thick scale with just 3 axles and the rest are not up there with them they will pull down unevenly causing the figures to be skewed. Thus not accurate. Besides here with a few more axles he would be legal on the weight. [u:dff30ebe39]His permit would have been able to go to 40,000 per tandem on the truck and trailer if had had them. That would have saved him a bit.[/u:dff30ebe39] Fines must have gone up a lot since I was last on the road. MI can charge in some counties as much as a 1.00 per pound.
So your saying he actually weighed way more than what the field weight with portables registered?(reply to post at 21:20:51 12/11/22)
What about safety of others on the road encountering an over width load?? Day or night?(quoted from post at 12:38:18 12/12/22) Permits are to help pay for the extra wear and tear on the roads, NOT safety. I don't care what the permit says. If does say "Safety" it's only because average truckers can't wrap their heads around "wear and tear on the roads" because they can't see any wear and tear after driving through.
This post was edited by BarnyardEngineering on 12/12/2022 at 07:38 am.
(quoted from post at 08:43:32 12/12/22)What about safety of others on the road encountering an over width load?? Day or night?
How about over height load causing damage to bridges, busting powerlines, etc.
(quoted from post at 09:05:19 12/12/22) So there should be more fines for over width, over length, over height, axle spacing, running at the wrong time, running a bad-for-load route, no proper escort(s) for the load, etc., etc.
Appears the officer let that Georgia violator off very easy or there are no fines for any of those petty violations.
