Heading to plow day
tomstractorsandtoys
I am heading to a local small plow day. 4020 with M&W turbo and f145 3 bottom 16 inch plow. Tom
Looks nice, Tom. Dumb question- what oil pan do you have on there with the M&W- stock 2 gallon, later 3 gallon? Appears to not be the M&W.
Just the stock 2 gallon. This turbo was added in the 70's and the tractor was not turned up. It was added for more fuel efficiency and not more hp. Tractor has led an easy life and has 6100 hours. Tom
I like going to plow days to watch and hope to have my Farmall 100 ready with a plow to go to one next year to actually participate. I've always like plowing and its fun to see someone else's money at work. Last year I went to a plow day and got to make a round on a F-20 a guy had there. I learned pretty quick how much nicer it is to plow with my H pulling the same plow.
That 4020 shouldn't know there is anything behind it unless you get up to 5th gear or higher. I have a similar set-up but my 3-16 was originally a 4-16 but has been cut down. Previous owner of the plow used it behind a JD 720 to plow up terraces.
Have fun at the plow day. Unfortunately, we are looking at high temps over 105F today so no plowing or tractor pulling for me today.
Same outfit as I have. Curious how you were able to load it backwards. I've loaded mine the other way but it puts a lot more weight on the truck. What's your deck length?
I thought I had the same plow, except mine is a four bottom, 16 inch. It makes my old Oliver 1850 grunt when the ground is like cement. kelly ALSO: How DO you load that outfit backwards???
used to pull a 4-18 oliver/ford behind my 4010 in 4th gear in hard gumbo,smoked a little but got er done. and i plow deep too.had to bolt weights on front though
