super99
On acceleration, when it gets to about 1900 to 2000 rpm it will sputter under a load but continues to increase rpm and smooths out about 2300 rpm. I changed the points and condenser today and took it for a test run and it still does it. It you slowly increase rpm's it doesn't miss, only when you shove the throttle all the way ahead. It has a vaccume advance on the distributor, I took it apart and cleaned and lubed everything inside the distributor but it still does it. Otherwise it starts and runs good. I know a lot of people change to a different distributor, could that be the problem??
