Geo-TH,In
Howes diesel treatment Prevents Fuel From Gelling - Howes Diesel Treat is the nations most trusted anti-gel. Its special formula has been tested and proven time and again to prevent gelling in even the coldest weather. Owners of all types of diesel vehicles and equipment rely on the Howes familys guaranteed product to keep them going all winter long.
Adds Lubricity - Diesel Treat helps protect against todays Ultra Low Sulfur Diesel (ULSD) fuels by providing added lubricity to injectors, pumps, and upper cylinders. In doing so, it extends the life and increases the performance of diesel engines of all types.
Prevents Deposits - More than just an anti-gel, Diesel Treat also contains a specialized detergent package to help prevent fuel injector deposits. Carbon deposits on diesel injector systems can cause loss of engine power and other issues. Preventing these helps to improve performance and fuel economy, saving you money.
Removes Water - Water is abrasive to your system and can lead to fuel filter icing. Many products emulsify or mix water into the fuel, often using harmful alcohols or solvents that can do additional damage to your engine. Petroleum-based Diesel Treat demulsifies water, safely pushing it out of the fuel using no alcohol or harmful solvents.
Can Howes do for gas engines what it claims to do with diesel engines? I add Howes to my Kubota before winter. A smart Kubota dealer from Tennessee recommended.
Can Howes be used in gas engines to remove water from gas? Remove Carbon deposits inside the engine?
Add Lubricity to cylinders and valves?
If not what is the gasoline version of Howes?
