I recently picked up a JD175 with a 14 HP Kawasaki engine. It's been in the family since new. It has been sitting up for approximately 2 years but was running when put up.
The problem. It cranks hard but when cranked runs until it's hot. Then it loses power and misses. If cut off when hot it will not start until it cools off. If not cold it will bog down and die. When trying to crank when hot it will backfire badly.
At least 10 years ago it acted similarly but would not crank at all. At that time the Ignition Coil was replaced which fixed the problem.
The question is, would you start at the Ignition Coil (AM101065) or would you start with the Igniter (AM131398)? I'm pretty sure that it's one or the other and I can replace both with online parts cheaper than I can take it into Deere and have them fix it.
Thanks
slim
Thanks
slim
