Lift arm pin has loosened and pulled out of the rear end hou
I have a new question for a 1954 Massey Ferguson 35.
The pins in the lower rear end housing attaching the lower lift arm seems to be anchored in place to the rear end housing.
My problem one of these pins has loosened and come out.I have not examed it closly yet but the hole must be worn or the anchor failed some how.Has any one out there had a similar problem and can explain how to re anchor this pin.
Pin is tapered. It's held by a nut on the inside of the rear axle "trumpet". It'll need to be removed to gain access to the nut. Replace pin if it's been loose.
