Indy dozer
New User
I have a 59 T340 with a sixway blade. It will not hold in the tilt in either direction. Any ideas where to look first? All other functions work correctly. Thanks Karl
As far as I know this is the orig. valve. I have only owned the dozer a short time. It had sat for a long time before I bought it. Is it possible that the seals could be bad in this cyl.?
Thanks karl
Sure, many have two opposed cylinders (What I thought yours had) and it makes sense that it could leak past the piston. Here is a check: switch the hoses on the angle control with those on the tilt.
If it still will not stay put, it is the piston seals, (should be rebuildable) JimN
I will check it out tomorrow. It is the smallest cyl. on the dozer so it should be easy to pull.
Thanks Karl
