Mornin ALL I'm new to the site, but not new to tractors, I'm the proud owner of a 1949 Ferguson TE 20, and my most recent find a 1950 JD"M", and this is no kidding , it was in a shed covered with a tarp ,hasn't been started in at least ten years,,all original good paint and air still in tires, now that I'm thru braggin ( I couldn't help it,,sorry) that brings me to my problem, the pto arms won't come up when I pull the lift lever back, I have the tractor running, in neutral, and the pto lever is engaged, I have added 10W oil to the breather tube located just in front of the seat no response, when I drove the tractor out of the shed when we first started it the lift arms went up and down 2 times,,but not since, I'm wondering if the oil has run out of the suction line to the pump,, and can I apply light air pressure to the breather pipe to maybe push oil up the suction pipe and to the pump to prime it and start it pumping?There is also a small valve like a radiator drain valve under the seat that when opened only oozes oil,,,,any suggestions would be helpfull Thanks Collosse
