B414 injector pump
Hi Guys, I own a 1966 B414 diesel farm tractor. I presume the injector pump has oil in it and it needs changed occasionally. There are two plugs on the bottom, one large and one small. I don"t see any plugs on the top. What is the procedure to change oil if this pump has oil in it? Thanks.
What engine and pump do you have? The original BD154 engine has a rotary CAV pump and does not have any engine oil in it.
The older BD144 engines used in the early B-275 tractors DO have oil-filled, in-line CAV pumps. These engines can be bolted into B414s, but are not original.
Guess I am a dummy. Need to know what make, model, year of tractor and make of injection pump before I can figure out anything. Tom
My tractor is a 1966 International McCormick B414. Serial no.is 46702. I don't think the engine has ever been changed so I would think it is the BD154 engine. Thanks for the information.
