Massey 165-Perkins engine manual
I have a Perkins D203 that I am about to overhaul. Is there a site I can go to to get all the engine rebuild specs? I have the head off and 1 piston has failed but I would like to check all specs before I order parts. I was going to buy a manual off this site but I don,t know how much it details the engine.
Any suggestions? Thanks,
Don from Canada
They have manuals on this forum to the left of your monitor's screen under "MarkekPlace". You probably should pull that engine and take the block, head and crankshaft to your local auto machine shop. Have them redo the head, clean the block and install new cam bearings. Have them measure the crankshaft & furnish the new bearings & to determine if it needs to be ground undersize and if the main bearings need to be linebored. -Sleeve kits are available on this forum too for about $350.00 for your tractor. Look under "Engine Kits". Hal
