long hydraulics
Anonymous-0
I have a long 2460 dtc w/ 1550c front loader.The loader works slow. Loader requires 10 gpm and tractor pumps 9 gpm. Hydraulics are hooked into remote valve under the seat. I heard there is a pump that operates off pto and is mounted just above pto. Does anyone know where I can get info on this pump and will it speed my loader up?
I have a pump off a Long 560, I kept this for a spare pump, but have traded my Long off. It does mount above pto and has a splned shaft for driving it, can still use original pto. Not sure of pressure or gpm, but loader hydraulics worked excellent. If interested I can get dimensions of pump. thanks Dick
I got some rough measurements, a steel plate about 4 3/4 x 6 1/8, and 4 bolt holes about 3 5/8 center to center and 4 7/8 center to center. And then a Vickers hydraulic pump monted in center of plate with in and out fittings and a splined coupler that connects to a shaft inside tractor, very simple to install, and as long as you have a reservoir you will only need hoses. I would sell for $50. plus shipping. If interested let me know. Phone 715-532-0383
thanks Dick
I am very interested in the pump, looks like the pump will fit the tractor. I tried to contact you at the number you gave me, but was unable reach you. Please call me at:
Home: 706-838-4825 (after 6 pm)
Cell: 706-633-0464 (daytime)
Thanks,
Tony
